Good Morning:
I am trying to figure out the JQL for returning more than one feature and all the linked child issues. The project I am working on is using features as the parent of user story and enablers.
Here is the query I have been able to use to identify 1 feature and all linked children issues but I need to return more than just 1 feature.
issue in linkedIssues(ABC-5668, "is parent of")
Hello @Peter Read
Have you established the parent/child relationship using generic issue linking, or is it based on the Issue Type Hierarchy?
Do you want only the issues that are direct children of the "features"?
If it is based on the Issue Type Hierarchy, then you can use a JQL like this:
issue in (feature-1, feature-2, feature-3) or Parent in (feature-1, feature-2, feature-3)
Hi Trudy, thank you for responding. No unfortunately the organization does not use the hierarchy as properly should be used...
We go:
Theme
Epic
Capability
Feature
Story
So I am trying to run a query to pull back all stories under many different features.
issue in (feature-1) only pulls back that feature...I need the is parent of link
Hello Peter,
So, you have not modified the Issue Type Hierarchy? Located here:
https://yourJiraUrl/jira/settings/issues/issue-hierarchy
That has just three levels?
Can you provide a screen image of a Feature showing how the Story issues are displayed within that Feature?
No the client will not allow us to reduce the hierarchy, it makes daily use very challenging.
Thank you for sharing that image. It is helpful.
Your post tags say you are using the Cloud deployment and Premium plan. That would indicate you are using the Jira Cloud product (the software-as-a-service product). However, the image you shared shows the issue details layout that is presented in the Jira Data Center product. Are you aware of how to identify whether you are using the Cloud or Data Center product? I ask because that is an important distinction and impacts the answers we provide.
Do you have access to any apps on that instance that extend the JQL capabilities of Jira? Can you create filters that use the syntax?
issuefunction in ....
If so, then there may be options available through the third party apps that can help with your requirement.
If you don't have access to third party apps in your Jira instance, your options are limited to linking multiple clauses together with OR
issue in (feature-1, feature-2, feature-2) OR issue in linkedIssues(feature-1,"is child of") OR issue in linkedIssues(feature-2,"is child of") OR issue in linkedIssues(feature-3,"is child of")
Hi @Peter Read
welcome to the community!
I understand that you're looking for a native/built-in approach to your problem - but just to put it out there in case it is useful: If you're open to solutions from the Atlassian Marketplace, there's a number of apps available that can help with this - either by extending JQL by additional functions, or by providing their own, more powerful search and visualisation techniques.
E.g., you may want to have a look at the app that my team and I are working on: JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a long list of advanced features, including support for (configurable) issue hierarchies. These issue hierarchies can be configured based on Jira's built-in parent/child relationships (like task/sub-task), and/or based on issue links of configurable issue link types (like is child of / is parent of).
This is how it looks in action:
In this example, WORK-106, WORK-107, and WORK-405 relate to their parent WORK-111 via issue links.
Once you've set up your hierarchy, you can easily narrow down your view to the set of parents that you are interested in.
I should also add that JXL can do much more than the above: From support for issue grouping by any issue field(s), to sum-ups, conditional formatting, or inline bulk edit via copy/paste.
Best,
Hannes
Hi @Peter Read
If you are running Scriptrunner plugin either in Data Center/ Server or Cloud then JQL Expression can resolve your issue.
You can run the below JQL Search using Scriptrunner Enhanced Search:
issueFunction in linkedIssuesOf(Subquery)
For example: First, you need to create a filter as Subquery, something like:
project = <project-name> AND issuetype = Story
Save this filter (eg: List of Story Issues) and add this Subquery in main JQL:
issueFunction in linkedIssuesOf("filter = 'List of Story Issues'")
This will give you all the list of Feature issues - where related Stories are linked to them.
I hope this helps.
For reference: https://docs.adaptavist.com/sr4js/8.0.0/features/jql-functions
Yep, what I am looking for is only the issues that are direct children of the "features"? But for several features not just the one as listed originally in this query...issue in linkedIssues(ABC-5668, "is parent of")
