We have a process that recurs twice a year. How can I reuse or copy the project I have now created. I want to keep the old one but also use the new one with new dates and maybe adding some new steps.
Thanks!
The Deep Clone app can clone any set of issue, even complete projects.
It is rather flexible and very popular. Give it a try!
Hi @Bente and welcome to the community 👋
As @Aron Gombas _Midori_ was so nice to mention, you can try our app Deep Clone for Jira.
Deep Clone can clone your template project with its Project Clone feature. You can find a detailed step-by-step in our documentation here.
If you want to change dates, or other custom fields, while cloning, you can take a look at our Clone and Edit feature. You can even use Jira Expressions to set your dates dynamically.
Hello @Bente
If you're willing to use a third-party application, I can suggest trying our Elements Copy & Sync app that allows you to copy issues with all their content (summary, description, custom fields, comments, attachments, etc.) and their child issues.
You’ll be able easily to copy your entire project.
Don't hesitate to try our app, it's free during 30 days and stays free under 10 users.
Let me know if you have any questions.
Clara
Hi @Bente
It's Mary from Planyway
In JIRA, you can replicate an existing project for a recurring process while retaining the original project. Here's a general guide on how you can do this:
Clone the Project Template:
Create a New Project:
Copy Workflow and Issue Types:
Copy Project Components and Versions:
Migrate Issues (if necessary):
Adjust Dates and Add New Steps:
Use Project Automation:
Documentation and Description:
Add-ons and Integrations:
Review and Test:
