×Hi Rajesh,
The easiest way is to use the automation feature for in project setting in JIRA which allows you to send an SMS.
You however need to have a Twilio account for this.
Potentially, you could also look at https://marketplace.atlassian.com/search?hosting=cloud&query=sms as one of these add-ons could fulfil what you are interested in.
Cheers
Hi Rajesh
This is also great integration using the powerful Infobip API sms and WhatsApp are available
Good luck
