Hi Team,
I am trying to create an automation rule that can send me a single slack notification listing all jira items that have been waiting in Final Review for more than 2 days. I have got the trigger working correctly where I am using a JQL query to find all the matching items and that is working correctly. But instead of getting a single slack message with all issues from the JQL I am getting a slack message per issue from the JQL.
Below is what I am using in the slack notification part of my rule.
*The following items have been waiting in Final Review for 2 days*
<URL for my work jira/{{issue.key}}|{{issue.key}}> - *{{issue.customfield_10370}}*
{{issue.customfield_10387}}
I looked up info on smart values and tried their simple examples such as
{{#issues}}{{key}}{{/}}
But still I receive a slack message per issue from the JQL
Any help and guidance from anyone would be awesome!
Hi Andrew! Welcome to the community.
I think this rule will solve your case.
I tried this and the listing of all the items in a message is working, however it didn't send me a single slack message. It sent me a slack message for the number of items.
So in this case my JQL query returned 4 matching items, so slaack sent me 4 messages with the same summary
Can you check if the checkbox under the 'Scheduled' section is unchecked?
You were 100% spot on! Had that enabled and now everything is working. Life changing!! Legend - thanks again @Dag Atle Stentad
@Dag Atle Stenstad you legend!
Will give this a go today and see how it plays out. Appreciate you taking the time to look into this and help me
