×I am giving rights to my team members to create the issue there own. I want the Assignee field must be filled with the Reporter. So if X create the issue the Assignee will be X, if Y create the issue the Assignee will be Y and so on..... The Assignee field must not be edited.
Hi @Jeetesh,
You can set the assignee field to invisible on the issue creation and editing screens, then set the postfunction “assignee=reporter” in the workflow configuration.
Thank you Ollie. I am trying with the solution given by you. Will let you know If I can do this.
Once again thank you so much.
