How to set Assignee same as Reporter?
Jeetesh August 29, 2018
I am giving rights to my team members to create the issue there own. I want the Assignee field must be filled with the Reporter. So if X create the issue the Assignee will be X, if Y create the issue the Assignee will be Y and so on..... The Assignee field must not be edited.
3 votes
Ollie Guan
Hi @Jeetesh,
You can set the assignee field to invisible on the issue creation and editing screens, then set the postfunction “assignee=reporter” in the workflow configuration.
Jeetesh August 31, 2018
Thank you Ollie. I am trying with the solution given by you. Will let you know If I can do this.
Once again thank you so much.
PVS
Banned
June 11, 2019
Like xuhaoting likes this
