Hi Sreenatha,
You can try the below and see if it works.
1. Set an initializer behavior to copy the value of "Current Monthly Revenue" to a temp field
2. On field change of "Current Monthly Revenue", set the behaviour to compare the value with the temp field and send error if it is below the value.
Let me know if it works.
Aditya
Hi! You can use Validators (Uniwersal Validator, ScriptRunner validator) on transition workflow, where you can check field value and show message.
