How to set jira issue type with script runner (2nd post)
meddows April 9, 2017
Hi The previous question by Adolfo Casari (Feb 15, 2013) which was marked as solved, pointed to a post which no longer exists.
Previous: https://community.atlassian.com/t5/JIRA-questions/How-to-set-jira-issue-type-with-script-runner/qaq-p/344276
Answer: https://answers.atlassian.com/questions/133053/changing-the-issue-type-with-groovy
I am stuck trying to change an issue type (via script runner) when it is created in the project via automation.
JamieA
April 9, 2017
The post does exist, it's just that Atlassian in their wisdom put the post in https://community.developer.atlassian.com.
But let's just assume that all the answers I've made over the last 10 years that had "development" tags have been lost so we'll start again.,
Changing the issue type is "moving" the issue. You may be able to use issue.setIssyeType(...) if you use that in the first post-function on Create transition.
meddows April 10, 2017
Hi Jamie. Thank you for your response.
I was able to get it working with your suggestion and then using issue.store().
MarcosQ July 14, 2017
Hi @JamieA @meddows did you were able to solve this? I need the same,  I have to change issue type of an issue in order to change the workflow. Can you please provide me the script that you use?
Thanks a lot!
Mark.
