The other question was from 2013, we use JIRA collector widget, the JS is located at:
/jira/s/d41d8cd98f00b204e9800998ecf8427e/en_UK-dt6y27-1988229788/6265/4/1.4.7/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js?collectorId=98e61d0c
What will require to set label in issue created using collector plugin. I've try to set this:
window.ATL_JQ_PAGE_PROPS = {
"triggerFunction": function(showCollectorDialog) {
$('footer .right a:last-child').click(function() {
showCollectorDialog();
return false;
"fieldValues" : {
'versions' :'10754',
'labels': 'Avenge-Rs' // also tried ['Avenge-Rs']
but when I call show dialog function there is no labels (only summary and title) and the label was not created. Can I have labels with this version? Is this old version of the plugin? Does it support labels, can I update this plugin (I can request to Admin). What should I request, if needed?
Did you ever figure out how to add labels to an issue collector?
No, no one answered the question. Awesome support. Even "You can't" is better then nothing.
