How to show only group options for comment visibility
Jyoti Kumari
Hello Team,
I want to show only one option i.e. group inside comment restriction for only one specific project and rest of the project should use project roles and group both for restricting comment.Kindly guide me, how we can achieve these through script or through configuration ,if possible.
Thanks and Regards,
Jyoti
PD Sheehan
October 3, 2023
There are no built-in or scriptrunner methods for controlling this.
At best, you can use scriptrunner and groovy to identify whether you should limit the list or not, and when you establish that yes, this is the correct context for limiting the groups, then you would inject some Javascript into the page using a Scriptrunner Fragment "Show a Web Panel"
The javascript you inject will need to include some sort of event listener that will watch for group options appearing, then override the list to hide the items you don't want to show.
Using the developer panel in your browser you can examine how the elements are identified.
For example, in my environment, I was able to get the list of groups with this:
AJS.$('#commentLevel-suggestions #groups li')
