How to start jira pod without starting jira
Lubos Valco May 18, 2025
Hello everyone,
I'd like to ask if it's possible to start a kubernetes pod without starting the application. many knowledge base articles have "Stop jira" as the first step but that's not really possible if it's deployed via kubernetes as far as I know right?
Our setup is official helm chart deployed on aws eks. My use case is testing out things and maintenance, manipulating file system which is locked when the app is running. when I shut down the pod I can't access the file system.
Big thanks in advance to any reply.
Lubos
Yevhen
May 18, 2025
@Lubos Valco command and args can't be overridden. What you can do, however, is declare additionalInitContainer that mounts shared home (or shared and local home if necessary) with some sleep infinity command:
additionalInitContainers:
- name: debug
image: ubuntu
command: ["/bin/bash"]
args: ["-c", "sleep infinity"]
volumeMounts:
- name: shared-home
mountPath: /shared-home
You can then exec into this init container and inspect the filesystem.
Lubos Valco May 19, 2025
thanks that worked
Like Yevhen likes this
