How to stop sending email for issue created or issue updated events in Jira?
Naveen April 20, 2018
I have no notification scheme assign for the project i want to achieve this but Jira still sends email when i create a new issue, can someone help me how to stop sending emails ?
Jack Brickey
The final cause is shown below. I have pulled it out of the comments so that we could check it as the solution so that others in the future might more easily find it.
from Naveen:
...finally i could able to figure out why it was sending emails without any notification scheme set and when event is not fired, it was notification assistant plugin which we use and the options in it were sending out emails :)
Jack Brickey
can you share a screenshot of your notification scheme screen?
I haven't assigned any notification scheme for the project i am facing this issue.
Jack Brickey
by default notification exist unless you turn the off. By looking at the notifications for the project it will answer the obvious question. For example here is one I have:
I have turned it off.
Jack Brickey
@Naveen, you indicate you have turned "it" off but i'm not sure what "it" means. Maybe you could illustrate this w/ screenshots. At this point you haven't provided a screenshot so I can't assess if this is an obvious issue w/ notifications or not. That said I will simply assume that you have removed ALL notifications in your notification scheme.
Andrew provides two considerations below. If this is about JSD and not JSW then this question is posted to the wrong thread. Please advise which we are dealing w/ here. He also mentions using Notification Helper and for sure you should try that and report back.
Danilo refers to the event fired and if desired you could remove the event fired on creation altogether. Not a normal thing to do and not necessary to prevent notifications generally but you can try it. edit the workflow, select the transition for Create, edit the post functions, select and remove the Event Fired.
Naveen April 23, 2018
Hello @Jack Brickey
Thanks alot for you reply.
This was on JSW, i haven't assigned any notification scheme to the project am dealing with, i checked everything and found nothing to suspect as mentioned by Andrew and Danilo.
But finally i could able to figure out why it was sending emails without any notification scheme set and when event is not fired, it was notification assistant plugin which we use and the options in it were sending out emails :)
Andy Heinzer
April 20, 2018
Is this a service desk project?  If so, Service Desk can send notifications using a completely different system than the one that is used to sent notifications for Jira Core and Jira Software projects.  If this is being used then the message should have a 'sent by Jira Service Desk' in the footer of the message.
More details on how Service Desk is different in this way:
https://confluence.atlassian.com/jirakb/jira-service-desk-notification-explanation-829045118.html
If this is NOT Jira Service Desk, then I would recommend trying to use the Notification helper,
https://confluence.atlassian.com/adminjiraserver071/jira-admin-helper-802593078.html
to better understand why you are actually getting these specific notifications.
Danilo Lima April 20, 2018
Check the Event Fired when you create a new issue... it could be triggered there..
Where should i check it?
Rilwan Ahmed
Workflow post function
Alfonso Leiva [ServiceRocket] April 20, 2018
Would that be due to the "notify my own changes" setting in your profile set to true? The default is false, but I think that's one place to check.
Hello Alfonso,
Thanks for the response.....
It is set to Do Not Notify Me already.
