Hi, I am evaluating Jira for our company's hardware & software development efforts-
Questions:
Thanks!
Hi @Jason Lin ,
Reading your requirements, I would suggest to have 1 Jira project for tracking Product lifecycle. You can create a new Issue type and call it 'Product'. Then model a Workflow for products that represents the product lifecycle you describe (the Grant 1 phases).
Next to this "Product lifecycle tracker project" you can create 1 Jira Project for each Product development project. These can be typical Software development projects, that uses Epics, Stories, Bugs and Tasks.
Per Jira project you can set permissions (by granting users a project role on the project).
This way you will have one high-level Jira project for tracking your portfolio of products. And one project for each product development initiative.
For question #6: a release is different from an Epic. Your Release (Fix Version) should represent a product version. And a product version will contain multiple Stories and Bug (fixes). These can be STories from one single Epic or multiple Epics. But there is not necessarily a 1-to-1 relation between the Release and an Epic.
Hope that helps.
Rik
Hi @Rik de Valk ,
Thanks for your quick and helpful response! Yes, I was just thinking the same to create separate projects for product management & product development.
Thanks!
The standard velocity is a report specific to a Scrum board. And it purpose is to show velocity per sprint. It cannot report per release.
However, you can create dashboards. And dashboards allow you to add and configure your own graphs and tables, based on filters you create. So you can create a filter for a release and use it to create a graph (EG: bar chart of completed issues per week).
For highlighting a scheduling conflict for Epics planned after their release date, you could use Plans. In a Plan the release icon above the timeline will turn red. And when you click on the release icon, it will show 'Off track by X days'.
Have a nice day! Rik
