How to synchronize two Jira instances
John Macmillan March 27, 2013
Is there a way to sync an OnDemand Jira instance with a local one? We have 2 instances of Jira and we would like to have 1 project synced between them automatically everytime someone makes a change. I tried searching for a solution but I didn't find anything decent in terms of difficulty (scripting the entire process is way too much effort).
3 votes
roman
March 24, 2017
Hi John,
Backbone Issue Sync for JIRA allows you to synchronize issues between projects or instances of JIRA. The add-on offers complicated configuration set up done through a minimal and easy-to-understand UI. Feel free to try it out and let me know if you have any questions.
Roman.
Andy Brook [Plugin People]
March 31, 2013
And for completeness I've also just implemented Sync Agent for JIRA, that provides a 2 way issue update/replication solution for stand-alone JIRA's. It uses email as a transport and JEMH for email content processing. It solves that touch subject of direct access through firewalls. Its oh-so nearly released, details at https://thepluginpeople.atlassian.net/wiki/display/JSA/ . Would be interested in a proof-of-concept...
Gustavo Rivera
April 8, 2013
Read the wiki on JEMH-Sync, looks promising, we have independent dev/qa labs in North and South America that I would like to sync, let me know if you need a beta-tester.
April 8, 2013
Hi Gustavo, sure thing, its a niche requirement, so a touch of real world requirements would be appreciated, it should be good to go in a couple of days! I'll announce releases on https://getsatisfaction.com/thepluginpeople if you signup, you'll know when its available.
Jobin Kuruvilla [Adaptavist]
March 29, 2013
Have a look at ConnectAll. We have done this usecase.
John Chin
March 28, 2013
Hi John,
I think this can be done by link a self-hosted JIRA instance to JIRA OnDemand with OAuth applinks, please see the example of document for more information:
https://confluence.atlassian.com/display/APPLINKS/Application+Links+Quick+Start+Guide
Hope it helps.
