×Hi @Vijay Sv,
I was looking for the same solution as you and I have already found it. You can try the addon Access Log for Jira, allows this monitoring (it only lists View Attachment, but also logs the download).
Cheers
Pavel
I think only with playing with the logs (application/tomcat). You can check what log shows when someone download (request) an attachment and later build parser to get that info in real time.
https://confluence.atlassian.com/confkb/how-to-enable-user-access-logging-182943.html
