×Hello,
I'm trying to create a dashboard to track how many bugs have been logged per story.
I'm using a link type to link defects to stories.
Some JQL and gadget suggestion?
Thank you in advance.
Hi @Jakeline,
I am Marlene from codefortynine.
Another option would be our app Dynamic Custom Fields for Jira.
With our app you can create a dynamic custom field which displays the number field of a specific type. Our app works with Jira expressions, but we offer a template for your use case.
After installation you simply
You can use the number field for JQL and issue statistics as any other Jira number field.
If you need help editing the expression, feel free to reach out to us.
Hi @Jakeline
I would use something like the following:
issue in linkedIssues("STORY_KEY") and issuetype = "defect"
This would produce the defects of the specific story.
