How to track issues resolved by DEvelopers
Malavi Lester
December 22, 2023
Normally, after the develeopment the stories or issues are tested by QA and moved to Done, In this case, QA will be the assignee while closure.
how do i track the no of stories or tasks a developer as worked on
Aron Gombas _Midori_
If I correctly understand your workflow, then you change the assignee of an issue when it moves from "development" to "testing" from its "developer value" to its "tester value".
If I were you, maybe it wouldn't do it, but use the "Assignee" field to store the developer and add an additional "User picker" type custom field with the name "Tester". That way "Assignee" would not change, and maybe tracking/reporting is more flexible and precise.
But if you want to keep your current workflow, then you could try to use JQL to collect the historical information. More precise, use the WAS operator on the Assignee field!
Sayed Bares _ServiceRocket_
@Malavi Lester welcome to the Atlassian community!
I believe Pie Chart Report addresses your use case. However, can you elaborate further? are developer and QA 2 different personas here? initially, it will be assigned to a developer and then to QA?
