How to track label history in jira in bulk
Rasajna Meka
I want to know  the list of issues whose label is changed from specific label
Rasajna Meka
Need other workarounds
Yuliia_Borivets_[SaaSJet]
Hi @Rasajna Meka
If you want to get label changes for the list of issues, check out Issue History for Jira. The app is developed by my team as a journal for all past changes. Here you can filter by project, sprint, label, date ranges, etc.
For your case:
1. Filter the issue list by label you need.
2. Choose the date range if you want some specific dates.
3. Add Labels issue field to the grid's columns (use Column manager).
Get your 30-day free trial and check if it's good for you.
Walter Buggenhout
Hi @Rasajna Meka,
Unfortunately history searches on the labels field are not supported currently in JQL. There is a feature request that you can track over here: JRACLOUD-44708
Hope this helps!
Rasajna Meka
Hi @Walter Buggenhout
Is there any other workaround or app available to pull this data?
