Hello!
Please tell me how to change the status for tasks correctly?
Given:
issueKey = "TEST-1"
currentStatus = "In Progress"
nextStatus = "Done"
So, the transition "InProgress -> Done" has an id = 900. Community documentation recommends using {{IssueService}}, which is what I am trying to do...
final String ISSUE_KEY = "TEST-1"
int ACTION_ID = 900
def issueService = ComponentAccessor.getIssueService()
// context of the currentUser
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// getting issue via IssueService
MutableIssue issue = null
def getIssueResult = issueService.getIssue( user, ISSUE_KEY )
if( getIssueResult.isValid() == true && getIssueResult.getIssue() != null )
issue = getIssueResult.getIssue()
else
return "Issue not found!"
def params = issueService.newIssueInputParameters()
def transitionValidationResult = issueService.validateTransition( user, issue?.getId(), ACTION_ID, params )
if( transitionValidationResult.isValid() == true )
def issueResult = issueService.transition( user, transitionValidationResult )
if( issueResult.isValid() == true )
log.debug "valid. Issue is = ${issueResult.getIssue()}"
return issueResult.getIssue()
else
log?.warn "error"
return issueResult.getErrorCollection()?.getErrorMessages()
else
return transitionValidationResult.getErrorCollection()?.getErrorMessages()
"${transitionValidationResult.isValid()}"
and, my result is:
[It seems that you have tried to perform a workflow operation (Resolve) that is not valid for the current state of this issue (TEST-1). The likely cause is that somebody has changed the issue recently, please look at the issue history for details.]
But, an issue TEST-1 haves the status "In Progress" and, this issue have the direct step/link to the "Resolved" status! Btw, i can change the status "In Progress" to "Resolved" manually, via IssueService - i got error.
So, how to transit an issues as correctly?
I could not move the task to the next status because it was an ISSUE_CREATED event. That is, at the time of creation of the task - it is not possible to move the task to the next status (but you can do it during the event ISSUE_UPDATED).
def srv = ComponentAccessor.issueService
class ThreadService extends Thread
private def srv = ComponentAccessor.issueService
private def threadUser
private Issue issue
public ThreadService(final ApplicationUser user, final Issue issue)
super()
threadUser = user
this.issue = issue
public void run( )
//Thread.sleep(1000); // delay for indexing
ComponentAccessor.jiraAuthenticationContext.setLoggedInUser(threadUser)
// there we can do transition
if (event.eventTypeId == ISSUE_CREATED)
Thread t = new ThreadService(event.user, event.issue)
t.start() // !!! no join for CREATED event !!!
else if(event.eventTypeId == ISSUE_UPDATED)
//srv.transition( ... )
IssueService issueService = ComponentAccessor.getIssueService();
IssueIndexingService issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService.class);
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters();
TransitionValidationResult validationResult = issueService.validateTransition(loggedInUserName, issue.getId(),
actionId, issueInputParameters);
if (validationResult.isValid()) {
issueService.transition(loggedInUserName, validationResult);
issue.setStatusId(statusID);
ComponentAccessor.getIssueManager().updateIssue(loggedInUserName, issue, EventDispatchOption.ISSUE_UPDATED,
false);
try {
issueIndexingService.reIndex(validationResult.getIssue());
} catch (IndexException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} else {
Collection<String> errors = validationResult.getErrorCollection().getErrorMessages();
for (String error : errors) {
// Logger.getLogger(error);
Try This, it will work!
Hi there,
I think your script looks fine, can I check that the ID 900 is the ID of the next status and not the ID of the transition itself?
I think from memory you need to provide the ID of the target status and not the transition itself.
