×This question is in reference to Atlassian Documentation: Advanced workflow configuration
I have a workflow with the status : Additionnal information.
I would like to know if it is possible that the issue becomes proposed automatically when a comment is added.
if it is possible : how ?
Thanks forr your response
Hi Aurélie Pilette,
You can do it.
image2016-6-18 17:44:31.png
WHEN Comment is added to an issue IF Issue matches: Comment is public AND User is a customer THEN Transition issue: Additional Information
Best Regards,
Lameck
I try your solution but when I make this, it doesn't work.
Dear everyone,
I hope this can help someone. In my case our service desk can select the status "waiting for customer" in the workflow and as soon as the customer comments the issue the status return to "work in progress":
Hi Michele,
I don't see the "initiator" when I try to set it up. Did you do something different to set that up?
I am facing the issue whereby status is transitioning even when the comment is from automated service desk alert.
I'd like the status to change only when the comment is created by the reporter.
Any ideas regarding this?
Hi Saurabh,
it's called user condition:
You should find it in the standard options.
Regards.
Because my problem is linked to the service desk.
A customer can't transition issue by the portal of the service desk.
He can only add comment or screenshot.
That's why I would like to know if there is a way to make that.
Unfortunately, it's not possible use a button at customer portal to do it. You need use comment and automation rule. :/
Being in the cloud you can't do listeners so I don't believe there is a way to capture that. You might want to rethink transitioning when any comment is added, it could be anything including someone commenting on the wrong issue. Why not just let them transition it to the new status with a transition screen for comment? That is what you are proposing in effect.
