How to transition an issue when comment is added
Aurelie Pilette
This question is in reference to Atlassian Documentation: Advanced workflow configuration
 I have a workflow with the status : Additionnal information.
I would like to know if it is possible that the issue becomes proposed automatically when a comment is added.
if it is possible : how ?
Thanks forr your response
4 votes
Meck
June 18, 2016
Hi Aurélie Pilette,
You can do it.
Step by step:
  1. Click on project settings
  2. Click on Automation
  3. Click on Add rule
  4. Select Transition on comment
image2016-6-18 17:44:31.png
  1. Setup an automation like this:
WHEN Comment is added to an issue
IF Issue matches: Comment is public AND User is a customer
THEN Transition issue: Additional Information
Best Regards,
Lameck
Aurelie Pilette
I try your solution but when I make this, it doesn't work.
Deleted user July 23, 2020
@Meck Would you know how to set up the condition for Comment is Public using Automation for JIRA.?
Michele_Lucchese April 5, 2020
Dear everyone,
I hope this can help someone. In my case our service desk can select the status "waiting for customer" in the workflow and as soon as the customer comments the issue the status return to "work in progress":
Saurabh_Lakshman April 30, 2020
@Michele_Lucchese
Hi Michele,
I don't see the "initiator" when I try to set it up. Did you do something different to set that up?
I am facing the issue whereby status is transitioning even when the comment is from automated service desk alert.
I'd like the status to change only when the comment is created by the reporter.
Any ideas regarding this?
Michele_Lucchese May 2, 2020
Hi Saurabh,
it's called user condition:
You should find it in the standard options.
Regards.
Like Saurabh_Lakshman likes this
Saurabh_Lakshman May 3, 2020
Thank you! That was helpful.
Aurelie Pilette
Because my problem is linked to the service desk.
A customer can't transition issue by the portal of the service desk.
He can only add comment or screenshot.
That's why I would like to know if there is a way to make that.
Joe Pitt
I see your problem, but I don't believe there is a solution in the cloud
Meck
July 6, 2016
Unfortunately, it's not possible use a button at customer portal to do it. You need use comment and automation rule. :/
Joe Pitt
Being in the cloud you can't do listeners so I don't believe there is a way to capture that. You might want to rethink transitioning when any comment is added, it could be anything including someone commenting on the wrong issue. Why not just let them transition it to the new status with a transition screen for comment? That is what you are proposing in effect.
