×Hello,
I have Jjupin Plugin installed on JIRA 7.1 and want to try auto transition the issue as per validation on linked issues.
Example:- I have parent issue type like (Story Task) and it has multiple child issue type (Task) which are linked to the parent (Story Task) both the issue types (Parent & Child) having different Workflows and I want to auto transition the Parent (Story Task) as per the status changed on all Linked issue (Task)
Here I am giving example I am using in SIL
Please assist how do I achieve this using SIL program with step by step configuration
if(isNull(parent)) { if (issueType == "Task") { string [] linkedIssues = linkedIssues(key, "relates to"); for(string linked in linkedIssues) { if(%linked%.status == "Design Completed") { return; } } } autotransition("Design Completed", parent); }
Hello Ligia,
In my scenario, all the child are Linked issue I am not using as parent-child (subtask)
All the relation is for Link issue i need to transition the main issue which is depends on linked issue it has.
Hi Akash,
It is a little bit confusing for me: do you have a parent issue and some children issues (like subtasks), or an issue and some dependent issues (linked with "relates to")?
The "parent" standard variable works only for subtasks. To identify the subtasks of an issue, you have to use "subtasks(<issuekey>)" instead of linkedIssues.
Hello Ligia,
I need to change the status of Linked Issue which has Link "relates to"
Example :- I have 3 project P1, P2 and P3
P1- issue type (UC story)
p2- issue type (UC story task)
p3- isue type (Task)
and the relations are
Linked p1–> p2–>p3
If ALL p3 issues are closed auto transition the p2 status to Closed and then auto transition the p1 status to closed
,Here is my updated script I am running this script as post function on transition (Closed) to every linked issue transitions
string sk;
bool allclosed = true;
string[] mylinarray = linkedIssues(key);
for (sk in mylinarray) {
if (%sk%.status != "Closed") {
allclosed = false;
if(allclosed) {
autotransition(Closed, %mylinarray%, true);
