How to trigger automation from another automation using REST API
Jayanth
In Jira Cloud, Is it possible to trigger an automation rule from another automation using REST API.
If so what is the endpoint we will be sending to trigger that rule.
Also, how to find the automation details including rule id using REST API GET request.
Martin Bayer [MoroSystems, s.r.o.]
Hello @Jayanth , you could try to use Incoming webhook trigger.
https://support.atlassian.com/cloud-automation/docs/configure-the-incoming-webhook-trigger-in-atlassian-automation/
You will get URL when saving automation rule with Incoming webhook trigger.
FREE
