How to upgrade Atlassian Connect Spring Boot project from version 1.5.3 to 2.0.0?
Chakresh Tiwari September 27, 2019
Hi
I want to upgrade My spring boot project from 1.5.3 to 2.0.0 but i am getting erros,
I tried to change the pom.xml version but not working instead getting errors like-
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/C:/Users/senthil-pc/.m2/repository/ch/qos/logback/logback-classic/1.1.11/logback-classic-1.1.11.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/Users/senthil-pc/.m2/repository/ch/qos/logback/logback-classic/1.2.3/logback-classic-1.2.3.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/Users/senthil-pc/.m2/repository/org/slf4j/slf4j-log4j12/1.7.5/slf4j-log4j12-1.7.5.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
Ignoring Class-Path entry lib/snakeyaml-1.13.jar found inC:\Users\senthil-pc\.m2\repository\org\liquibase\liquibase-core\3.5.3\liquibase-core-3.5.3.jar as C:\Users\senthil-pc\.m2\repository\org\liquibase\liquibase-core\3.5.3\lib\snakeyaml-1.13.jar does not exist
INFO 9/27/19 5:48 PM: liquibase: Can not use class liquibase.logging.core.Slf4jLogger as a Liquibase service because it does not have a no-argument constructor
Exception in thread "restartedMain" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.boot.devtools.restart.RestartLauncher.run(RestartLauncher.java:49)
Caused by: java.lang.AbstractMethodError
at org.springframework.context.event.AbstractApplicationEventMulticaster.supportsEvent(AbstractApplicationEventMulticaster.java:289)
at org.springframework.context.event.AbstractApplicationEventMulticaster.retrieveApplicationListeners(AbstractApplicationEventMulticaster.java:221)
at org.springframework.context.event.AbstractApplicationEventMulticaster.getApplicationListeners(AbstractApplicationEventMulticaster.java:192)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:128)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:122)
at org.springframework.boot.context.event.EventPublishingRunListener.environmentPrepared(EventPublishingRunListener.java:73)
at org.springframework.boot.SpringApplicationRunListeners.environmentPrepared(SpringApplicationRunListeners.java:54)
at org.springframework.boot.SpringApplication.prepareEnvironment(SpringApplication.java:336)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:307)
at com.acis.itsm.AddonApplication.main(AddonApplication.java:25)
... 5 more
17:48:21.929 [main] DEBUG org.springframework.boot.devtools.settings.DevToolsSettings - Included patterns for restart : []
17:48:21.932 [main] DEBUG org.springframework.boot.devtools.settings.DevToolsSettings - Excluded patterns for restart : [/spring-boot-starter/target/classes/, /spring-boot-autoconfigure/target/classes/, /spring-boot-starter-[\w-]+/, /spring-boot/target/classes/, /spring-boot-actuator/target/classes/, /spring-boot-devtools/target/classes/, /spring-boot-starter/target/classes/, /spring-boot-autoconfigure/target/classes/, /spring-boot-starter-[\w-]+/, /spring-boot/target/classes/, /spring-boot-actuator/target/classes/, /spring-boot-devtools/target/classes/]
17:48:21.932 [main] DEBUG org.springframework.boot.devtools.restart.ChangeableUrls - Matching URLs for reloading : [file:/C:/Users/senthil-pc/Desktop/cloud/acis-itsm-for-jira/target/classes/]
Any suggestion??
George V
November 30, 2020
Try `atlas-mvn clean`, you may have leftover class files from a previous build.
