How to use the same transition (and transition id) for multiple steps in Jira workflows?
Sorin Sbarnea (Citrix)
March 3, 2013
I observed that it is possible to have the same transition for multiple steps in Jira workflows.
Also, it seems that Jira is displaying these transitions using italic.
I find the reuse of transitions as very handy but I wasn't able to find how to reuse them.
If I add a new transition it will ask for the name and the other parameters, but even if I enter the same name, it will create a new one.
How can I solve this?
5 votes
Janet Albion
March 3, 2013
Hi Sorin,
If you are using latest JIRA instance, you can use either Global Or Common Transition which can be configured in the Diagram Edit mode only ;)
Further reading at https://confluence.atlassian.com/display/JIRA/Advanced+Workflow+Configuration#AdvancedWorkflowConfiguration-Workingwith'commontransitions'
March 3, 2013
Wow, I wouldn't expect to have features available only on the Diagram Edit mode.... that's a shame. Thanks.
Janet Albion
March 4, 2013
Sorin,
You can also add Common Transition using workflow XML. But, it can't be added in Text Mode.
galund-qinec
August 26, 2015
That this still hasn't been fixed is pretty strange.
Deleted user September 23, 2013
Use the diagram mode to draw the transition between states. You will be prompted for transition details. A radio button in that dialog window will offer "Common Transition"
Ezequiel Muns
October 21, 2013
Which version of Jira are we talking about? In 6.1.1 there is no 'Common Transition' radio.
paul vinter October 24, 2013
HomeAway's comment is indeed not necessarily the case.
Alfons Braunhuber January 20, 2014
@HomeAway's comment refers to the classic Diagram Mode
Timothy
March 3, 2013
Download the default JIRA as XML and open it up. You'll find them under <common-actions>.
curt klyn
April 4, 2018
Thanks, all! I've got the solution
MattS
March 9, 2015
I had to sue the Classic Workflow Designer to see the Common transition option with JIRA 6.1. Later versions of JIRA added this feature into the standard workflow designer
Tolga Şen March 2, 2014
in JIRA 6, the functions 'reusing and cloning transition' are ignored in new ediyor. You need to switch to classic editor in order to use those function. On the other hand, new feature is created to fix this problem on new editor and waiting for your support. Vote it, Comment it, watch it to show how important it is.
https://jira.atlassian.com/browse/JRA-37296
