×My Jira working directory and Jira home directory are in different locations
The upgrade wizard asks for 'existing installation directory', how do I confirm which one is correct for the system upgrade?
Hi @yannickwilson ,
the installation directory is where you have the Jira binary application. It is different from your Jira Home directory. It will likely be something like atlassian-jira-8.5.x-standalone for example.
Let me know if this helps,
--Alexis
Thanks for your input
I am running Windows so the path might be slightly different
But I figured that the directory where the start and stop scripts were would be a indicator
C:\Program Files\Atlassian\JIRA in my instance
