How to write a Script in CLI?
Siddheshwar mhetre
July 21, 2013
I am using CLI Plugin. So is this possible to write a script usin CLI?
RambanamP
July 23, 2013
check here for example of CLI commands for attachments
https://bobswift.atlassian.net/wiki/display/JCLI/Examples
Bob Swift
July 23, 2013
Follow the Installation and Use instructions and then look at the examples related to attachments as rambanam pointed out.
Anand Kumar Singh July 22, 2013
Hi Bob, I am getting the same problem.Please ,Can you provide some example for writing Script in CLI ?
Bob Swift
July 22, 2013
Siddheshwar mhetre
July 23, 2013
Hi Bob, I want to addAttachment in Remote machine, So how can I do that using CLI commands?
Nic Brough -Adaptavist-
July 23, 2013
Siddheshwar - the documentation tells you how to use that command in the CLI. It's the first line on https://bobswift.atlassian.net/wiki/display/JCLI/Documentation
Siddheshwar mhetre
July 22, 2013
Ya, exactly that I need. Thanks Bob. I will try it. I will write CLI actions from programming scripts ,so I will prefer a Groovy for writing a script. Thank you once again Bob.
RambanamP
July 21, 2013
Siddheshwar mhetre
July 21, 2013
hey thanks, its very useful... We can use this using commands, but there is also possible using the script's. So you know how to write script for that?
Bob Swift
July 21, 2013
A bit confused by what you mean by script. You can use the run action to run all the actions listed in a file for instance - this is sometimes referred to as a script. You can also run CLI actions from programming scripts like groovy or any other scripting language. Is that what you are trying to do?
RambanamP
July 21, 2013
did you checked Database values plugin to get values from external db?
https://marketplace.atlassian.com/plugins/org.deblauwe.jira.plugin.database-values-plugin
Siddheshwar mhetre
July 21, 2013
ya.. but I want that databaseusing CLI Script only.
July 21, 2013
Yes it is.
If you need more information, you'll need to tell us more about what you are doing. You haven't really given us much to work with here.
Siddheshwar mhetre
July 21, 2013
ok.. I want to access anthor database in JIRA. So I want to know that how we can access this using CLI? where we can write a script? and how we implement this script in our JIRA.??
