I would like to create a transition in my workflow that will change the assignment to a specific project role and notify the assignee of the new issue.
I have followed all the written information on how to do this and have created a workflow with an appropriate post function in the transition but the assignment does not occur.
The role has been defined and there is only one person in the role.
Here is the post function list:
Thanks for any help you can send my way!
Solution was to move the role assignment to the project level. This was an overlooked step.
Does the person performing the transition have the right to set the assignee?
What do your logs say?
Hi Nic,
Thanks for helping out.
Yes, the person has the rights to set an assignee. It can be done manually as well but I need this to be automated.
We are using OnDemand and have not been able to access any kind of log (or console). I would love to see what is actually happening so if you know how to get to the logs using OnDemand that would also be a big help.
