We need possibility to change commit-messages in subversion and we want them to be updated in jira. Because of the incremental indexing of subversion-plus-plugin, usually they are not updated, I think a nightly re-indexing will do that.
how can we force subversion-plus to re-index the repositories. How ca we automate this?
Seems, there is no possibility for reindexing a whole repository. The suggestion to do it inside the database ist no solution for us, so we haver to wait or to build a plugin by ourselves...:-(
There are directions in the documentation on how to re-index. It is not a clean process since sometimes communications between the plugin and svn breaks down and you need to restart indexing or restart Jira.
Do you mean there is not any way to continue indexing after some error accessing to a repository? This sounds like a bug as there are not too much reasons for that. It should continue as normal by:
All the three above actions should continue indexing repositories after some network issue. If the indexing process stops indexing forever then there is a bug somewhere.
I couldn't find those directions in the documentation, could you give a hint?
Which version of subversion plus and Jira are you running since the directions changed as subversion plus developed into subversion alm. Also it would helpful which indexing structure you are using if you had a choice.
The general case was stop jira, delete a directory/database, start jira
You do not need to re-indexing.
You can do it by using the web console (please see the animated gif attached in this issue SVN-59) which requires JIRA admin privileges or doing something similar by writting your own custom plugin using the public JAVA API to provide a GUI to allow others to make those modifications
Thanks for the answer. I would prefer to do that globally without knowing which jira-issue might be affected by a changed commit message. Developers here won't do what you showed in the animated gif even if we built a plugin, they will foget... 'That's why I thought of re-indexing...
If I understood this well then it is not possible. Developers are the only persons knowing the issue that a commit is affecting to and this cannot be replaced by any automatic global process.
The plugin might help when a developer forgets or types a wrong issue key in the commit. In these cases it would be possible that the developer (or another person) fix the mistake without re-indexing the full repository from the beginning by following some of the instructions above.
There are add-ons on the Markeplace forcing developers to type a valid issue key in the commit message based on some rules. Maybe, they might be useful for you to avoid developers breaking traceability.
OK, I thought of something like deleting the index of subversion-add-on an rebuilding it from scratch, reading the subversion-commit-messages from the beginning every night. Perhaps that might become a performance issue but not having tried it, I would never know.
Therefor I do not have to know which commits or issues are affected by changed messages. In my eyes this might be possible but eventually not implemented.
