Hi Team,
I Need help on how to integrate GitHub to Jira cloud Instance. I require a detailed steps regarding the same. What actions need to be performed while implementing.
Thanks and Regards,
Bharath.
Hi Bharath - Welcome to the Atlassian Community!
Connecting to GitHub is pretty straightforward. Follow the guidance in this support document:
https://support.atlassian.com/jira-cloud-administration/docs/integrate-with-github/
This is a common integration and relatively easy to get started with. You have two main options: use Atlassian’s GitHub for Jira app, or go with a more advanced integration depending on your use case.
Here’s the basic setup using GitHub for Jira (free app from Atlassian):
If you want deeper integration—like syncing statuses or updating custom fields based on GitHub activity—OpsHub Integration Manager can help by:
Offering a plugin-free setup, Jira and GitHub stay easy to maintain, and users can integrate on-premises instances with SaaS.
Hope it helps!
