I connected a jira project to a wrong slack channel. How can i disconnect that project?
Julia
September 24, 2019
I connected a jira project to a wrong slack channel. How can i disconnect that project from that slack channel?
Trevor Thompson
September 24, 2019
@Julia if you type /jira manage in that channel, it will send you a link to manage the connection. From there you can delete the connection.
Removing the bot from the channel will also do this (/remove @jira
Julia
September 24, 2019
Thank you for your answer! Found it!
Like Trevor Thompson likes this
Deleted user September 24, 2019
Hi @Julia ,
You can always leave the group by clicking on the leave option from the settings dropdown of the respective sack channel.
Sravya
