I have logged as sudo user Nd gave the permissions to the folder but i could not able to stop jira as the error is displayed
If you encounter issues starting or stopping JIRA, please see the Troubleshooting guide at http://confluence.atlassian.com/display/JIRA/Installation+Troubleshooting+Guide Server startup logs are located in /opt/atlassian/jira/logs/catalina.out Using CATALINA_BASE: /opt/atlassian/jira Using CATALINA_HOME: /opt/atlassian/jira Using CATALINA_TMPDIR: /opt/atlassian/jira/temp Using JRE_HOME: /opt/atlassian/jira/jre/ Using CLASSPATH: /opt/atlassian/jira/bin/bootstrap.jar:/opt/atlassian/jira/bin/tomcat-juli.jar Using CATALINA_PID: /opt/atlassian/jira/work/catalina.pid
PID file found but either no matching process was found or the current user does not have the permissions to start the process. Stop aborted.
& Do i need to give the permissions to the ctalina.pid by chmodd -R 777 Catalina.PID.
Can any of you guide me on this part .
Hi Priyanka,
To check if whether the service is still running, run ps -A | grep jira
Pass the -force
parameter to catalina.sh
as:
catalina.sh stop -force
Please refer to https://confluence.atlassian.com/jirakb/the-jira-application-doesn-t-terminate-after-shutdown-script-is-executed-222200632.html
