  • Community
  • Products
  • Jira
  • Questions
  • I created a new project using an existing projects configuration in JIRA Core, but it did not bring over the Boards tool (page) to the new project, any ideas why?
Melissa McGough May 10, 2016
Original project whose configuration used :
New project created using original projects configuration:
Can someone please assist?
Ignacio Pulgar
May 10, 2016
The boards so linked to a JIRA Core project (and not to a JIRA Software one) is part of Core Labs, and it is currently subject to certain restrictions, including:
  • Only new projects created with business project template will have access to a board
Nic Brough -Adaptavist-
May 10, 2016
Boards are not project artefacts, they're independent of the projects.  So copying a project won't copy a board, as it's not part of the project.
You'll need to use "create new board" and probably select "from existing project"
Ah, I see. Thanks! How do I create a new board?
May 10, 2016
There should be a "create" option on the boards menu.
