I got a problem as when i create a project only Business section is showing and software section is
Eyad
October 9, 2022
Whenever accessing the project section only business projects option is available and software projects not showing at all including kanban and scrum ones
John Funk
Hi Eyad - Welcome to the Atlassian Community!
Where are you looking at that? Can you share a screenshot?
Nic Brough -Adaptavist-
October 9, 2022
This would usually be that you don't have Jira Software installed.
Jimi Wikman
I am assuming that this is on the Project creation screen where things are a bit confusing..
You can change the application at the bottom of the left side column, which is a bit difficult to see. Once you choose Jira Software for example, then you will see Kanban and Scrum again on the right side.
FREE
