I got the issue while adding values in custom field in jira, Few days ago I insert values directly in to the db
Onkar Ahire
April 17, 2013
Cause:
com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:CustomFieldOption][id,10815][sequence,7][value,TEST][customfieldconfig,10400][parentoptionid,null][disabled,N][customfield,10300] (SQL Exception while executing the following:INSERT INTO dbo.customfieldoption (ID, CUSTOMFIELD, CUSTOMFIELDCONFIG, PARENTOPTIONID, SEQUENCE, customvalue, optiontype, disabled) VALUES (?, ?, ?, ?, ?, ?, ?, ?) (Violation of PRIMARY KEY constraint 'PK_customfieldoption'. Cannot insert duplicate key in object 'dbo.customfieldoption'. The duplicate key value is (10815).))
Stack Trace: [hide]
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.createValue(DefaultOfBizDelegator.java:379)
at com.atlassian.jira.issue.customfields.manager.DefaultOptionsManager.createOption(DefaultOptionsManager.java:132)
at com.atlassian.jira.issue.customfields.manager.CachedOptionsManager.createOption(CachedOptionsManager.java:155)
at com.atlassian.jira.issue.customfields.option.OptionsImpl.addOption(OptionsImpl.java:124)
at com.atlassian.jira.web.action.admin.customfields.EditCustomFieldOptions.doAdd(EditCustomFieldOptions.java:204)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
at webwork.action.ActionSupport.invokeCommand(ActionSupport.java:433)
at webwork.action.ActionSupport.execute(ActionSupport.java:157)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:82)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:221)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:150)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:153)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:78)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:40)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
at com.atlassian.labs.remoteapps.modules.permissions.ApiScopingFilter.doFilter(ApiScopingFilter.java:60)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:234)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:738)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.atlassian.labs.remoteapps.modules.oauth.OAuth2LOFilter.doFilter(OAuth2LOFilter.java:70)
at com.atlassian.labs.remoteapps.util.http.bigpipe.RequestIdSettingFilter.doFilter(RequestIdSettingFilter.java:22)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:74)
at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:CustomFieldOption][id,10815][sequence,7][value,TEST][customfieldconfig,10400][parentoptionid,null][disabled,N][customfield,10300] (SQL Exception while executing the following:INSERT INTO dbo.customfieldoption (ID, CUSTOMFIELD, CUSTOMFIELDCONFIG, PARENTOPTIONID, SEQUENCE, customvalue, optiontype, disabled) VALUES (?, ?, ?, ?, ?, ?, ?, ?) (Violation of PRIMARY KEY constraint 'PK_customfieldoption'. Cannot insert duplicate key in object 'dbo.customfieldoption'. The duplicate key value is (10815).))
at org.ofbiz.core.entity.GenericDAO.singleInsert(GenericDAO.java:136)
at org.ofbiz.core.entity.GenericDAO.insert(GenericDAO.java:101)
at org.ofbiz.core.entity.GenericHelperDAO.create(GenericHelperDAO.java:64)
at org.ofbiz.core.entity.GenericDelegator.create(GenericDelegator.java:487)
at org.ofbiz.core.entity.GenericDelegator.create(GenericDelegator.java:467)
at org.ofbiz.core.entity.GenericValue.create(GenericValue.java:98)
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.createValue(DefaultOfBizDelegator.java:374)
... 166 more
3 votes
Mizan
April 17, 2013
Onkar Ahire
April 17, 2013
Thanks Mizan It works.
Great.
Regards
Onkar Ahire
Nic Brough -Adaptavist-
April 17, 2013
Actually, Mizan's link, while telling you how to fix this, misses an important point here.
You have damaged your data. You should NOT do anything with SQL in the database unless you know exactly what you are doing. In this case, you've neglected to update the counter table, and if you've missed that, I suspect you may have missed other things too.
Also, you did take Jira offline while you did this insert, and re-index afterwards?
Onkar Ahire
April 17, 2013
Hi Nic,
I had shutdown jira before updating the db,after the update I had reindex jira, I was not aware of the counter table, I did not notice any exceptions after the update, can you please explain more about the counter table? What should I do now ?
Thanks!
April 17, 2013
Stop Jira again, and correct the damaged values in sequence_value_item. You don't need to re-index this one, but it is cached and you need to have Jira offline.
It's quite easy to do though - find the item(s) you have added (from what you've said, probably issue and customfieldvalue, but you may have added other things), and bump the related numbers up above the corresponding IDs in the associated tables. For example, if you added 5 issues, you'll have created 5 new IDs in table jiraissue, so you need to increase the value for "issue" by at least 5 (or rather, anything above the highest number in the issue table)
Mizan
April 17, 2013
As Nic said , you have neglected to update the counter . The PK ID is autoincremented . I had inserted values to an AO table where I use to provide 1 in case of PK
eg: insert into AO_xyz values (1,"Mizan",23) ; here 1 is PK , name and age .
I always test SQL queries in a test environment before applying to live database .
Erwin Manuel
Awesome. Thanks guys!
Erwin Manuel
Yes I am in dev, jira stopped, db backed up. You are right I missed the counter.
The last ID in customfieldvalue is 35454426
However, current CustomFieldValue SEQ_ID is 35454500
What ID should I start inserting? What SEQ_ID should I put in after the insert, lets say for example I added 100 rows?
July 3, 2013
You don't need to follow any precise rules, as long as the number you put in is larger than the highest number you used as an id when adding your data. I usually add a few more and round it up to the next 10
Onkar Ahire
July 3, 2013
Onkar Ahire
July 3, 2013
Hi Erwin,
As I learnt the same from above as you are experiencing now, I refer
[https://developer.atlassian.com/display/JIRADEV/Custom+fields]
Erwin Manuel
Hi All,
I am also attempting this maneuver, I will add customfield values for some issues. My custom field already exists so I am thinking I only need to insert rows in table customfieldvalue alone. Ofcourse I also know the last ID of customfieldvalue so lets say the last ID was 1100 then I can insert ID's 1101,1102,1103 and so on... The question is do I need to make updates to counter tables like Onkar did? I looked into schema and it looks like there is no dependent key to customfieldvalue table's ID. Is my plan somehow safe? Thanks!
July 3, 2013
No, there's a counter for custom field values as well. Same table as the other counters - sequence_value_item
And I can never say this one enough - it is absolutely critical that you backup your database before trying any SQL on it. You also have to have Jira shut down while doing it, and you MUST re-index afterwards.
Onkar Ahire
April 17, 2013
Hi Nic,
May I know overall details of database structure for customfield and their dependencies.
Regards
Onkar Ahire
Onkar Ahire
April 17, 2013
Thanks Mizan,Nic.
I didn't got the chance to apply it on test server because of an emergency on production server and not that much awareness about counter table, now I have made a correction in it and learnt many things out from that :) .
Onkar Ahire
April 17, 2013
Hi Nic,
Regards
Onkar Ahire
April 17, 2013
See https://developer.atlassian.com/display/JIRADEV/Database+Schema - bear in mind that it changes between releases though, so you may need to read older versions...
Onkar Ahire
April 17, 2013
Thanks Nic,
This is exactly I am looking for understanding.
Regards
Onkar Ahire
