I have a JIRA agile project. But i dont remember whether it is Scrum or Kanban. Can you help me in finding it?
Gokul K January 9, 2015
Boris Berenberg
January 9, 2015
Find out what kind of board it is? You should be able to tell by the UI. Does it have a Plan button in the upper right? This would be a Scrum board. If it does not, then it is Kanban.
Yes i can see Plan button on the right top. Thanks.
