I have a created an issue but need to move it to an existing Epic?
Deleted user February 5, 2019
I have created an issue have a BU number. I need to move this into an existing Epic. How can I do this?
Ravi Varma
February 5, 2019
Hi @[deleted],
You can do either one of these:
  • As you have already created an issue, you need to add "Epic Link" field to your issue screen and you should be able to select the EPIC that you want this ticket to be assigned to
  • Navigate to the board and select the issue from the backlog and drop the issue into the relevant EPIC section on the left panel of the board (Refer below image)
Ravi Varma
