I have a problem when installing Jira on my CenOS server
Minh Bui June 4, 2016
This question is in reference to Atlassian Documentation: Installing JIRA on Linux
Hi there,
Please help me to resolve this problem. I installed JIRA versio 7.1.7 on our server then I got this problem. Please check it out:
http://vietlandsoft.com:8082/JiraLockedError
Thank you and look forward!
Minh Bui
Nic Brough -Adaptavist-
June 5, 2016
The link times out for me.
What does your log file say the error is?  It should be telling you why it's failing - jira-home/logs/atlassian-jira.log
Minh Bui June 5, 2016
Hi Nic,
Thank you for quick response. Please see below image:
June 5, 2016
You need to read the log file to see what is going wrong.
But, this error is usually something on https://confluence.atlassian.com/jirakb/troubleshooting-jira-startup-failed-error-394464512.html - try those first, and if you still get the problem, you must read the log
Thank you so much! I installed it successfully
