×I had created a project with a number of Issues, The project has been automatically changed to new experience and I cannot see my issues anymore on the board.
Hi I am presuming that JIRA has changed a template which caused my issues not showing. It did happen to me in the past.
It has not changed anything. When you created the project, you selected the Nextgen option.
Hi Nic and thanks for your reply, I am not sure what I did but at the top of the project there was a note informing " Congratulations for using next generation project etc...".
I had my issues showing in the dashboard some time ago but know the project is empty.
I have discovered the issue, after 14 days Done issues are not visible anymore. I would be great if i can still have them visible in Done/Implemented Column.
Is there a way how i can set this?
Hi @Gerald Vassallo,
What you mean by "automatically changed to new experience"? Could you please clarify?
