I have a problem with a Jira Project
Gerald Vassallo November 26, 2018
I had created a project with a number of Issues, The project has been automatically changed to new experience and I cannot see my issues anymore on the board.
Hi I am presuming that JIRA has changed a template which caused my issues not showing. It did happen to me in the past.
Nic Brough -Adaptavist-
November 26, 2018
It has not changed anything.  When you created the project, you selected the Nextgen option.
Hi Nic and thanks for your reply, I am not sure what I did but at the top of the project there was a note informing " Congratulations for using next generation project etc...".
I had my issues showing in the dashboard some time ago but know the project is empty.
Gerald Vassallo November 27, 2018
I have discovered the issue, after 14 days Done issues are not visible anymore. I would be great if i can still have them visible in Done/Implemented Column.
Is there a way how i can set this?
Mirek
Hi @Gerald Vassallo,
What you mean by "automatically changed to new experience"? Could you please clarify?
