I have a strange settings issue - HSQL shows on Admin, but settings is mySQL
Glory Leung March 17, 2013
I upgraded to latest from 4.1.2...
Now on my admin screen it says that i'm using HSQL, but in my JIRA Configuration Tool, it is set to MYSQL.
Is there anything wrong with my settings?
Also:
WARNING: The system property 'mail.mime.decodeparameters' is not set to true.
but when I go to the settings, it's already set to true.
petry
March 18, 2013
Hey Glory, may I ask you which process did you followed to upgrade your instance?
Also, if you were using a JIRA WAR, you probably have the DB configuration in the JIRA_HOME/dbconfig.xml and JIRA_INSTALL/conf/server.xml file as well (one pointing to a HSQL database). Can you double check it?
Glory Leung March 18, 2013
I was on 4.1.2,
then I did the following:
  1. backup DB XML
  2. Uninstall 4.1.2
  3. Install 4.3.3
  4. Upgrade to latest
  5. Configure to MYSQL
  6. Import XML
