I have created a project and when i have create issue in it. it will go to open issue not coming in
abhishekk February 6, 2020
I have created a project and when i have create issue in it. it will go to open issue not coming in.I have to change the status to inprogress then it will come in Sprint.
Avinash Bhagawati _Appfire_
Hi @abhishekk ,
Can you please check your scrum board columns configuration. Also as @Callum Carlile _Automation Consultants_  mentioned you can set the sprint value in create issue screen.
Avinash
Hi @abhishekk ,
I don't quite understand the problem, are you wanting to find a way to get issues that you create into the current sprint?
You may need to add the Sprint field to your create screen for that issue type, then you are able to directly move the issue to the sprint, without having to change the status or assign it to someone
I have created a sprint but when i create issue then it will go to open issue and not showing in my backlog. then i again change the status to IN Progress then only it will come in my active sprint.
