No I don't.
If you are on the later versions of JIRA, you wouldn't see it under the 'Commit' tab. Instead, you will see it under the development panel (provided you have the permission for that). Are you able to see it there?
If you are not seeing the panel itself, please check whether you have the "View Development Tools" permission or not.
I am using JIRA v6.1.7 I have created application link for Stash and Fisheye/Crucible. Initially all commits attached with isuues were visible under commit tab.Now they are not visible
Can you see any of the other features under AD-1, such as the branches feature?
