  • Community
  • Products
  • Jira
  • Questions
  • I have installed your plugin and created a simple project with 2 epics and 2 issues per epic but the system is not displaying the project correctly
JohnM
July 1, 2015
Marlon Grawer July 21, 2015
As Robert said, including some more details in your question would help you in achieving the proper answer. One thing you can do in order to try fixing your display issues is to uninstall the plugin and then install it again.
In case it doesn't work, make sure of update your question including the plugin name and screenshot from the issued screen.
Robert Massaioli (Atlassian)
July 1, 2015
Which plugin? I think editing this question and including some more details would be helpful. :)
