×Hi guys,
I am trying to figure out on how to add a value in a custom field with JMWE and I'm new to nunjucks.
The field is a group picker field that needs to be filled in when specific conditions are met.
Depending on these conditions it will be a different group that needs to be added to the field.
Following seemed the most logical, however it does not work.
{% set issue.fields.customfield_10063.name = "myGroup" %}
Anyone here that knows how to solve it? Or point me in the general direction?
Thanks in advance,
Dave
Hi @Dave Bosman [Realdolmen] ,
you can use a Set Issue Fields post-function, select the destination field (your Group Picker field), and for the value use something like:
groupName
Of course, if the group name depends on some conditions, you'll need to add some Nunjucks code. What is the condition that drives the group name?
