I'm admin Jira and using Jira cloud, I cannot map isse type screen scheme with issue type scheme
I have to map an issue type screen scheme with a project, here is what I did:
1) Create screen scheme
2) Create Issue type screen scheme = map screen scheme wwith issue type
3) Now, I think I need to map issue type screen scheme with issse type scheme but i don't know how (I already mapped issue type scheme with project)
5 votes
Harshit Grover
December 5, 2024
@TRẦN THỊ KIM THOA - ITC - CTO Office - IT Project Management Executive
To map Issue Type Screen Scheme, you have to perform following steps :
Project Settings > Screens> Click On Actions Button > Use a Different Scheme > From Drop-Down Select the Issue Type Screen Scheme that you want to associate with the project > Save
Harshit Grover
Thank you, I finally can do it.
Like Harshit Grover likes this
Harshit Grover
December 5, 2024
If the solution worked for you, would you mind marking it as the accepted answer? This helps others who may have the same issue find the solution more easily.
Harshit
Harshit Grover
December 5, 2024
Hi @TRẦN THỊ KIM THOA - ITC - CTO Office - IT Project Management Executive ,
You have to map Issue Type and Issue Type Screen Scheme to the Project not to each other.
Please follow the below article to know more :
https://support.atlassian.com/jira-cloud-administration/docs/associate-issue-types-with-projects/
https://support.atlassian.com/jira-cloud-administration/docs/manage-issue-screens/
Harshit Grover
Yes,
I already:
  • Mapped issue type and Issue type Scheme, then mapped Issue Type Scheme to the Project.
  • Then, I mapped Issue Type and Issue Type Screen Scheme as you said.
However, Issue Type Screen Scheme still not map with the project. Screenshot 2024-12-06 135531.png
