I'm evaluating add-on for Zephyr and ReQtest. I have installed both but only Zephyr shows up in Jira
Håkan Andersson
November 8, 2018
Is it not possible to run them at the same time? If not how do I switch between them?
Christopher Jaksch
November 8, 2018
Hi @Håkan Andersson,
as far as I understand ReQtest is a standalone application like TestRail that you can connect/integrate with Jira.
Test management will be processed outside of Jira (https://help.reqtest.com/jira-integration/).
Zephyr on the other hand is a fully integrated test management app in Jira.
Hope that helps you.
Best wishes
Chris
STAGIL
