I'm not able to add my workflow to my projects
Jorge Barrientos
July 1, 2020
I've created my workflow but when I am adding it to an specific project, I don't have the "workflow" option to sync it with my project.
John Funk
Hi Jorge - Welcome to the Atlassian Community!
You cannot modify the existing workflow for a Next-gen project, nor can you link another workflow to a Next-gen project. You can only work with the one that gets created with the project. And even then you can only modify it by adding columns on the board.
Aisha M
Hi @Jorge Barrientos , Did you assign your workflow to a workflow scheme ?
Thank you
FREE
