I'm totally crazy with next issue: Done tiquets are still In my backlog !!!
Anna Marcilla November 16, 2018
First, I thought it was related to workflows and I changed them.
But, now with the same workflow I have some projects are working well and other are still wrong.
Nic Brough -Adaptavist-
November 17, 2018
An issue is "done" when it is in the last column on the right hand side of a board.
If it's not in that column, then it will appear in the backlog, because it is not "done".
Anna Marcilla November 18, 2018
hI nic,
Thanks for your answers :)
I know what you said.
But, I don't expect in my backlog, closed issues (with status done) from previous closed sprints.
Why they are still showing up in my backlog if they are already closed?
 Anna
November 18, 2018
Were these "closed" issues in the last column of the board when you ended the sprint?  Is the "done" status in the last column on the board?
More important info I left before:
I don't want to show up Tiquets from previous Sprints
