I moved a project and now my other project is stating it needs required fields
Nick April 18, 2016
Its stating it needs required fields that are only required for my new project.  What is the problem?
Nick April 18, 2016
Its weird its saying the fields are required.  Even though the fields are not required the production environment!!
Nic Brough -Adaptavist-
April 18, 2016
You've told it the fields are mandatory, so, to be consistent, it needs them filled in.
Check that the field configuration for the old and new projects are consistent with what you need - they do sound like they need to be different.
Joe Pitt
Sounds like the field configuration it being used for the old project. Perhaps someone updated the default field configuration and it is used by both.
